Create polygons of specific size using geodesic measurements
4288
12-14-2021 08:06 AM
Labels (3)
emilyOSU
Hi all,
I am trying to create polygons of a specific size from a known point using a geodesic measurement mode. For example, I have a known point and want to create a polygon that is 100m x 30m starting at that point. I figured out how to do it by right clicking while I am creating the feature and setting the distance. However, I just realized it was doing that with a planar measurement mode. Unfortunately, I am far enough from the equator that I have a big error with that. I there a way to set the mode for the distance function in Create Features to be geodesic?
Thanks!
DanPatterson
MVP Esteemed Contributor
Construct geodetic features—ArcGIS Pro | Documentation
There are limited feature types that you can create.
Fodder for the "Ideas" community, if there is enough cases where this might be a widespread practice.
... sort of retired...
emilyOSU
Thank you! That gets me closer. I was hoping to draw rectangles instead of ellipses and circles.
LaileDiSilvestro
Have you found a workaround?
