Create Polygons Based on Corner Lat/Long
7056
5
03-24-2021 06:25 AM
Labels (3)
IJurgensen
I have a table of data with left, bottom, right and top lat/long values and need to create a grid using those corners for rectangular polygons. The data has specific values I need to be able to show in pop-up once the layer is complete. Essentially I'm creating a national grid, and would like to show data for each rectangle that is being charted.
What tool should I be using to do this? Any tips? Thank you for the help, I'm new to ArcGIS!
JayantaPoddar
MVP Alum
In ArcGIS Pro, you could check Coordinate Table to Polygon
Think Location
IJurgensen
I used the Coordinate Table to Polygon tool, and was able to create a layer showing the top left corner of each of the rectangles, but I don't see anywhere to define the other corners of the shape. Ie it has one lat/long entry field, but nowhere else to define the rest of the shape. Am I missing something?
JayantaPoddar
MVP Alum
Could you share a sample table?
Think Location
IJurgensen
Certainly! This file would be 3 rectangles in TN. You can see I have the lat/long coordinates for each of the 4 corners of each rectangle, or can use the individual lat/long of the 4 sides of the rectangle. The tools that I've found have all only allowed for one set of lat/long, which allows me to create a layer with data at one of the 4 corners of the rectangles, but not see/color/interact with the entire rectangles themselves. I need to be able to create all of the rectangles, and have the polygon be recognized so that a pop-up will appear when clicked showing the data for that rectangle.
Thank you for your help!
by Anonymous User
Not applicable
Hi!
a few other options to check out are 'minimum bounding geometry' and the 'points to line' > 'feature to polygon' toolsets.
Ive used the points to line>feature to polygon workflow a fair bit, and if its something you intend on repeating a lot, a model could help shorten the process in the long run
have a read here for more info - https://support.esri.com/en/technical-article/000021848
