Create Mosaic dataset using Landsat Collection 1 level1
874
09-13-2021 11:40 PM
Labels (2)
Teeheish_Comm
Hello!
I am trying to create a mosaic dataset using Landsat Collection 1 level 1 images (landsat 4-5). In the Add Raster to Mosaic Dataset I selected Landsat 4-5 TM as the raster type, and Surface Reflectance as Processing Template. However, I receive the following error
Add Rasters To Mosaic Dataset
Parameters
Mosaic Dataset F:\Landsat\ARCGIS_PRO\Landsat_Trial_1\Landsat_Trial_1.gdb\Landsat5_Mosaic_2
Raster Type Landsat 4-5 TM @ F:\Landsat\ARCGIS_PRO\Landsat_Trial_1\Landsat_Trial_1.gdb\Landsat5_Mosaic_2\RasterType.OBJECTID=1
Input Data 'F:\Landsat\Data\1\Bulk Order 20210909_092718\Landsat 4-5 TM C1 Level-1\LT_05'
Update Cell Size Ranges UPDATE_CELL_SIZES
Update Boundary UPDATE_BOUNDARY
Update Overviews NO_OVERVIEWS
Maximum Levels
Maximum Cell Size 0
Minimum Rows or Columns 1500
Coordinate System for Input Data
Input Data Filter *.MET;*_wo.txt;*.wo;*_mtl.txt;*.mtl;*_mtlold.txt;*.xml
Include Sub Folders SUBFOLDERS
Add New Datasets Only ALLOW_DUPLICATES
Build Raster Pyramids NO_PYRAMIDS
Calculate Statistics NO_STATISTICS
Build Thumbnails NO_THUMBNAILS
Operation Description
Force this Coordinate System for Input Data NO_FORCE_SPATIAL_REFERENCE
Estimate Mosaic Dataset Statistics ESTIMATE_STATISTICS
Auxiliary Inputs
Enable Pixel Cache NO_PIXEL_CACHE
Pixel Cache Location C:\Users\Teeheish\AppData\Local\ESRI\rasterproxies\Landsat5_Mosaic_2
Updated Mosaic Dataset F:\Landsat\ARCGIS_PRO\Landsat_Trial_1\Landsat_Trial_1.gdb\Landsat5_Mosaic_2
Messages
Start Time: Tuesday, September 14, 2021 2:23:45 PM
2021-09-14T14:23:49.073: Loading raster datasets
2021-09-14T14:23:58.421: Completed crawling 423 data source items. Added 0 mosaic dataset items.
2021-09-14T14:23:58.425: Error: 8004205f: No new mosaic dataset item was added.
Succeeded at Tuesday, September 14, 2021 2:23:59 PM (Elapsed Time: 13.36 seconds)"
Tags (1)
