Create Mobile Map Package crashing when run from ModelBuilder
1493
12-15-2022 06:12 AM
RobertBorchert
Honored Contributor
We create a Mobile Map Package in Pro by Sharing and Mobile Map.
We would like to create a model to export the map and then upload it to the appropriate group in Portal
The Geoprocessing application
Create Mobile Map Package crashes and knocks me out of Pro every time I try to run it.
I am trying to save it to a directory and not in Portal.  Using ArcGIS Pro 3.0.3
Using default settings.
This happens with or without locators set and with or without Area of Interest defined.
I have tried it with very small amounts of data and it still aborts.   No message just the standard Stopped working message
RobertBorchert
Honored Contributor
I tried multiple things.
I had it set up to path to a unc directory
I changed it to send the map package to my C: drive instead and it worked as expected
Robert_LeClair
Esri Esteemed Contributor
Robert - I created a model using ArcGIS Pro 3.0.3 as well that has the Create Mobile Map Package GP tool in it.  I have a raster dataset and a point feature class for data.  Saving local and not to ArcGIS Online.  Ran the model and it worked fine.   ArcGIS Pro did not crash.  Whenever I see "weird" GP issues such as this a few things to try.
1.  Rename the ESRI folder in your C:/Users/<user_profile>/appdata/local and C:/Users/<user_profile>/appdata/roaming to ESRI_OLD.
2.  Delete your GP history.
3.  Clear your  Display cache from Project->Options->Display
Hope this helps!
RobertBorchert
Honored Contributor
Robert_LeClair
When I ran the GP tool in a model, my output path was C:\temp so no issues/crashes.  I wonder why the C: drive works but other paths do not.  Regardless, it seems you have a solution.
