Create Line segments from Point Locations referencing Linear feature
12157
13
12-12-2022 07:08 AM
kapalczynski
Starting point:
  • I have a point file that denote Start and End Locations
  • I have a road file that should to the roads
I am trying to create road segments that start at the start point and end at the end point.  So I am trying to extract those road segments in-between the sets of points.  NOTE:  There can be overlap between Start/End Point 1 and Start/End Point2.  So I need multiple road segments in the output that might have overlap between them.
I started by Snapping the Points to the road.
I also have a similar Points file that is snapped and Dissolved  by a unique identifier.
I have network analyst but I am very rusty.....Any thoughts on how I can achieve this?
JaySandhu
I think your input data is already set up to be used directly. So try this:
Convert your point feature class to a table using the Export table tool and write to a table called TSM_FeaturesOutp_ExportTable and then use the Make Route Event Layer to create your lines as follows:
Hope this is the output you are looking for.
Jay Sandhu
kapalczynski
@JaySandhu  @AyanPalit  AWESOME... THANKS SO MUCH for your help thoughts and guidance...
This stuff is so tricky... especially getting your data in the correct format... Cheers....
AyanPalit
@kapalczynski Glad the suggestions worked out for you. Do take some time to further review the linear referencing concepts using links provided previously. I am also moving the post from Network Analyst to ArcGIS Pro.
@JaySandhu Thanks for tag teaming with me!
Ayan Palit | Principal Consultant Esri
kapalczynski
Great thank you both again... If anyone reading this wants any further into please feel free to reach out
