Create layer view from ArcGIS Pro
5472
05-21-2021 08:06 AM
Labels (2)
JPIERRON
I've been struggling with this all day.
I have created several feature layers from arcgis pro, and searching how to create views based on said feature layers, but can't find any way to do so.
I know i could create these views from arcgis online after publishing the corresponding feature layers, but as i'm aiming to apply different filters on the views than those i use on the feature layers, it would be nice to do it all directly from arcgis pro.
Is there a way to create a layer view based on a feature layer from arcgis pro i'm missing ?
Thanks
DanPatterson
MVP Esteemed Contributor
Make Feature Layer (Data Management)—ArcGIS Pro | Documentation
but not sure what you really need from your description
... sort of retired...
Todd_Metzler
Do you mean that in ArcGIS Pro you want to consume the hosted feature layer and visualize a subset of those data?  Definition query.
AdrianWelsh
MVP Honored Contributor
As far as I know, the only way to create a hosted feature layer view is only within ArcGIS Online, not within Pro.
https://doc.arcgis.com/en/arcgis-online/manage-data/create-hosted-views.htm
ShelleySchott
@JPIERRON , Have you had a look at creating Query Layers?
Query layers are SQL queries stored in maps in ArcGIS Pro projects, however they only work with Enterprise Geodatabases.
Here are a few links to have a look at:
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/creating-a-query-layer.htm
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/what-is-a-query-layer-.htm
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/make-query-layer.htm
Shelley Schott
Senior Consultant, Esri Australia
