Create Fishnet Not Updating On ModelBuilder
1154
11-19-2023 07:58 PM
JayWee
Hi All,
I'm having issue updating Create Fishnet extent coordinates based on an output.
When i ran the Model, the Fishnet Extent coordinates seems to get stuck on the previous polygon that i've used to setup the model.
Can i please find out whether anyone have a solution for this please?
Thanks in advance.
DanielCross
Did you ever figure out how to get the extent to update?
I am trying to make a tool where the user will select a area from a drop down menu.  But the fishnet extent does not update, it just uses the values from the default area.
