Create database connection for Oracle
2017
11-13-2023 12:33 PM
JummaKhan
I am using Pro 3.1. I don't find an option to add Oracle database connection.
and how I can import connection from ArcMap Desktop?
Thanks
Jumma
George_Thompson
Esri Notable Contributor
George_Thompson
This is how you connect in ArcGIS Pro: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-oracle/connect-oracle.htm
You can also use the .sde file from ArcMap and add it to your project: https://pro.arcgis.com/en/pro-app/latest/help/projects/connect-to-a-database.htm
--- George T.
David
by Esri Contributor
Last year we created a standard workflow that quickly and easily synchronizes schedule data that is tied to GIS data. We have released the open-source Schedule Sync ArcGIS Pro Toolbox which enables this synchronization workflow. Included in the toolbox are tools for the syncing of schedules in a wide variety of formats. The Sync ArcGIS Pro Toolbox is compatible with the outputs from the most common scheduling platforms including Oracle Primavera Cloud, P6 Professional, P6 EPPM, Microsoft Project, Asta Powerproject, InEight, and any scheduling platform that can export CSV, Excel, or P6 XML files.
5-minute video: Construction Schedule Integration with GIS
If using ArcGIS GeoBIM, there is a similar way to integrate schedules as well. Introduction to Schedules in ArcGIS GeoBIM
