Create a Definition Query that Shows Only Most Recent Record
1652
6
09-22-2025 08:15 AM
ChristopherBowering
I have a table where some inspections records have the same ID (associated with the same parent feature) but have different dates based on when inspections were done.  I would like to create a query which only shows the most recent record when multiple records with the same ID exist.  There is obviously nothing 'out of the box' for this so I imagine a custom SQL definition query will be necessary.  I am not too familiar with scripting outside of basic Arcade.
Tags (5)
Laura
by MVP Regular Contributor
I just did this for my inspections relationship!
Use this to create database views of your table. https://community.esri.com/t5/arcgis-survey123-questions/select-display-most-recent-record/m-p/10403...
I set mine up by 'inspection date'. Each hydrant is inspected multiple times but this just returns the most recent inspection per hydrant.
ChristopherBowering
I was hoping for a more simplistic approach than creating views or involving the relationship.  Maybe there isn't one, however.  I don't really care about the parent feature class itself.  If you think of it as a basic standalone table - say, with Field X and a Date field - and you just want a definition query to see the most recent record for each Field X value that exists.  That's what I'm going for.
RhettZufelt
MVP Notable Contributor
This should work for definition query, use your fields:
created_date IN (SELECT TOP 1 created_date FROM FeatureclassName ORDER BY created_date DESC)
R_
ChristopherBowering
I did try this.  However, it only shows 1 singular record as a result.
I want to be able to see the most current record amongst multiple with the same ID.  For example, GUID of XYZ only has one record; GUID of YYY has 5 records; GUID of ZZZ has 2 records, etc.  It's a 1-to-many table.  For each GUID value, I only want to see the most current record.
JoshuaBixby
MVP Esteemed Contributor
What is the context?  Is this for labeling, visualization, analysis, etc...?  Knowing the context can open the door to context-specific options.  Regarding SQL, it is complicated because SQL support depends on the back-end data source, and the more advanced the SQL the less standard the support becomes.  That is, SQL isn't always very portable as a solution.
ChristopherBowering
The context is visualization.  Ultimately, I would publish this table to a web service and use in a WebApp. Users could view the table and only see the most current record when there are multiple tied to a parent feature.
@JoshuaBixby
