Create 3D borehole in local scene??
5135
09-01-2021 08:39 AM
OliverCostello
I have a table containing a collection of straight (not deviated) well bores each a X and Y a surface elevation of 0 ft and a negative total depth value in feet below surface. Total depths range from -1000 to -20000. Values for each well bore are in a single row in the table.
I am trying to create a well bore line/tube or other connecting the surface point to the total depth below surface. I'm not sure what kind of feature this might be, a series of points, line, polyline??
I've been researching this for days and I've seen examples here and there so I think it can be done but I have not been able to accomplish it yet. Any ideas?? Much thanks.
JayantaPoddar
MVP Alum
Could you check if the steps in How To: Convert 2D points to 3D lines using 'from' and 'to' values  work for you?
Think Location
JayantaPoddar
MVP Alum
Think Location
OliverCostello
I was unaware of Extrude under Appearance in local scene. I held my breath and there they were! Awesome! I've been flailing around w this for days. Thanks!
David_Brooks
MVP Regular Contributor
Relatively straightforward, you can either build on the workflow suggested by @JayantaPoddar and then add the final step which is a 3D buffer of the polylinez layer, or you can just extrude your points into lines with a neagtive extrusion, run the FeatureTo3D tool and then buffer that polylinez
It's the 3d buffer that will get you a cylinder 👍
David
..Maps with no limits..
