Thank you for your assistance. i just want to mention issue clearly. actually we have pdf files, don't have CAD files. so we changed CAD pdf files into CAD dwg format using AutoCAD software. after changing into CAD DWG format, i imported them into arcGIS pro, georeference the feature dataset - particular class with coordinate system, but it is showing somewhere on the ocean. here i would like to understand one thing with your help:
Do i need to do anything else AutoCAD software when converting from pdf file to CAD DWG format ? to resolve the issue, is there anything else can i solve this one with myself or
Do i need to approach the builders who did it for solving the problem?
please give your thoughts on it ?
