Counting Points and/or Point Density Along a Linear Feature
1779
03-14-2022 01:20 PM
GarrettRSmith
Hello
I have some point data representing campgrounds that are ranked from 1-5 (1 having the lowest and 5 having the highest impact score) that are located along recreation trails (line feature). Is there a way to either count the points along the line, maybe the density of points? Or, can I calculate a value for the line segment based on the 1-5 values of the points?
Thanks for any suggestions.
DavidPike
MVP Notable Contributor
Spatial Join (Analysis)—ArcGIS Pro | Documentation can give you a count of all points intersecting each line, and the field_map can calculate a statistic on a field such as mean, median etc.
