Copying Data into a Geodatabase Version with Arc Arcade and Attribute Rules
880
12-20-2022 02:03 AM
StefanAngerer
Hello ESRI Community,
I am wondering if it is generally possible to use Arc Arcade and attribute rules to automate the process of copying data into a specific version of a geodatabase. It is important to know that the copy process should happen from the default version of one gdb to a version of another gdp. Specifically, I am looking for a way to trigger the copy process when a user updates the database version.
I have been trying to figure out if this is possible using Arcade scripts and attribute rules, but I have been having some difficulty figuring out the correct syntax and conditions to use. Is this something that is generally possible to do in ArcGIS Pro, or are there other tools or approaches that would be better suited for this task?
Any insights or guidance you could provide would be greatly appreciated. Thank you in advance for your help!
Best regards,
Stefan Angerer
