Converting shape file into xaml
942
08-16-2022 10:38 AM
ParhatM
Hey guys,
I'm working on setting up the Pro (3.0) startup interactions (polygon selection) with Configuration Manager on Visual Studio 2022 but I couldn't figure out how .xaml files (with its .cs codes) are created for scenarios where the polygons are created out of a dataset. One typical example is the "Californiacounties.xaml" in the sample data. I tend to believe there's got to be some tools that can do the work by converting polygons (in Shape or any other map format) into .xaml.
I couldn't find the tool from ArcGIS Pro either. Can you guys please give me a clue?
Many thanks,
Parhat
