Converting LAZ to LAS without LASzip
4288
07-03-2023 12:34 PM
RobertCarroll
I am trying to convert LAZ files to LAS. Every tutorial I have found says to download LASzip. The problem being that the download link on LASzip.org gives a 404 error. I need to find a way to use the LAZ files downloaded from USGS and without LASzip it doesn't seem like that is possible.
swfbtucs
Go here to download: https://rapidlasso.de/customer-support/ LASzip.exe is included in the LAStools.zip package as free software.
sjones_esriau
You can also use the Convert LAS tool within Pro if you have the required license.
Luke_Pinner
MVP Regular Contributor
You could use PDAL. Installation instructions in the Quickstart
pdal translate input.laz output.las
MicZatorsky_AEC
The Data Interoperability extension (FME) - ASPRS Lidar Data Exchange Format (LAS) Reader/Writer will take you from LAZ to LAS  (more here https://community.safe.com/s/article/reading-point-clouds)
