Convert sql query to Arcade Expression
1552
05-19-2025 12:08 PM
JoshLay1
I have a simple sql expression used to filter on a layer in ArcGIS Pro
Field1 = 'Open' AND Field2 = 'LP' AND Field3 IN (10, 11, 12, 13, 14)
I would like to convert it to an Arcade Expression for use in a Velocity filter.  Below is what I have come up with so far but it is returning some syntax errors.
$feature.Field1 = 'Open' && $feature.Field2 = 'LP' && $feature.Field3 IN (10, 11, 12, 13, 14)
Does anyone have suggestions how to convert the sql query to a arcade expression?
Thanks
Tags (3)
RyanUthoff
MVP Regular Contributor
The Arcade expression below might work. I think you'll need double equal signs. And the syntax for "IN" is a little different in Arcade. https://developers.arcgis.com/arcade/function-reference/array_functions/#includes
$feature.Field1 == 'Open' && $feature.Field2 == 'LP' && Includes([10, 11, 12, 13, 14], $feature.Field3)
RyanUthoff
JoshLay1
The Arcade Expression you provided works perfectly.  Thanks for taking time to solve my problem.
Tim-Woodfield
Would Includes() work in a data expression with the Filter() function? I would be trying to convert the "=" to SQL IN to account for a comma separated list.
Filter(project_table, `Contractor_Assigned = '${user_company}'`)
I don't have the full array list of possible values to compare to with Includes() but have been trying to use Distinct() to create it from the field.
