Convert shapefile polygons to polylines in Model Builder
2025
05-28-2024 02:46 PM
norcal916
I was wondering if there is a way to automate the following process in Model Builder: How To: Convert Shapefile Polygons to Polylines (esri.com)
I'm stuck on steps 9-14 in the ArcGIS Pro section of the linked page.
I don't have an advanced license for ArcGIS Pro so I don't have access to the Feature to Polyline tool.
Matthew_Muehlhauser
There's a pretty straightforward way that you could do this with Python, and you could convert it into a script tool as well to use going forward. Although, in my version I work mostly in a GDB.
import arcpy
# Gathering layer and field info
project = arcpy.mp.ArcGISProject("CURRENT")
mv = project.activeMap
lyr = mv.listLayers("POLY_LAYER_NAME")
desc = arcpy.Describe(lyr)
shape_name = desc.shapeFieldName
oid_name = desc.OIDFieldName
flds = [fld.name.replace(shape_name, "SHAPE@").replace(oid_name, "OID@") for fld in arcpy.ListFields(lyr) if "Shape_" not in fld.name]
shape_index = flds.index("SHAPE@")
#Create Empty Line Feature Class
workspace = lyr.connectionProperties["connection_info"]["database"]
result = arcpy.management.CreateFeatureclass(workspace, f"{lyr.name}_line", 'POLYLINE', lyr)
line_path = result.getOutput(0)
# Get the polygon features and convert to lines
features = [list(row) for row in arcpy.da.SearchCursor(lyr, flds)]
for ftr in features:
    geom = ftr[shape_index]
    ftr[shape_index] = arcpy.AsShape(geom.JSON.replace("rings", "paths").replace("Rings", "Paths"), True)
# Insert new line features into new Line Feature Class
with arcpy.da.InsertCursor(line_path, flds) as cursor:
        cursor.insertRow(ftr)
 The reason I used the json for the geometry is because this version accounts for multipart features and curves just by changing the "rings" to "paths" and the "curveRings" to "curvePaths".
One other thing is that I did a bit of substitution to change the Shape field to "SHAPE@" and the OBJECTID to "OID@". "Shape@" and "OID@" are keywords for the different cursors and it's easier to work with those so you don't have to worry about the actual name, which can be apparent in the beginning where we get the names from the Describe object.
norcal916
Thank you. I tried using the code you provided but I received the following error:
File "<string>", line 27, in <module>
TypeError: cannot alter multipart geometry type
Matthew_Muehlhauser
Did you end up making any changes to the script? It's hard to tell for sure without seeing your data, but based on the error, my guess is it has something to do with the fields not matching up exactly. I didn't do too much testing myself, so you might just need to try running the below lines and see what it gives you:
And  then try comparing it to the result of:
[fld.name for fld in arcpy.ListFIelds("Line_Layer_Name")]
Keep in mind though that this second line doesn't replace the ID or shape fields with the "@" version, so there will be those two differences for sure.
If they are different, then you might need to find a way to account for that.
