Convert grid lines to polygons
3957
06-16-2022 06:49 PM
Bud
Legendary Contributor
I have a SQL script that quickly generates grid line features, for testing purposes, using whatever grid dimensions I need: Generate SDO_GEOMETRY grid using SQL
  • The result is a spatial view (can be easily exported as a feature class).
  • I'm aware that there are GP tools that can generate grids too. But for my use case, I like this SQL option.
  • The lines are split at the intersections. So this 10x10 grid has 220 lines:
Question:
Is there a way to convert the grid lines to polygons? (i.e. a polygon for each grid cell)
I tried creating a polygon envelope FC and then I looked for a GP tool that could split the polygon via multiple lines. But I haven't found a GP tool that can do that yet.
Advanced license: ArcGIS Pro 2.6.8 and ArcMap 10.7.1. Oracle 18c EGDB.
Tags (1)
Maps-Berlin
The "feature to polygon" tool can do it no?
Bud
I suppose one way to do it would be to modify the existing query:
Details:
(1) Keep only the horizontal lines. Exclude the vertical lines.
where
startpoint_y = endpoint_y
Here's a sample horizontal line:
  OBJECTID STARTPOINT_X STARTPOINT_Y ENDPOINT_X ENDPOINT_Y SHAPE
       219            0            0          0          1 [SDO_GEOMETRY]
(2) Add an additional outer query where we generate 5 vertices (a polygon) from the existing 2 vertices (from the original horizontal line):
startpoint_x, --vertex 1 (original vertex from the horizontal line)
startpoint_y,
endpoint_x, --vertex 2 (original vertex from the horizontal line)
endpoint_y,
endpoint_x, --vertex 3
endpoint_y+1,
startpoint_x, --vertex 4
startpoint_y+1,
startpoint_x, --vertex 5 (same as vertex 1) https://gis.stackexchange.com/q/433083/62572
startpoint_y,
(3) Just like with the lines query, construct a polygon geometry by concatenating the coordinates together into WKT.
sdo_geometry('polygon(('||startpoint_x||' '||startpoint_y||', '||endpoint_x||' '||endpoint_y||', '||endpoint_x||' '||(endpoint_y+1)||', '||startpoint_x||' '||(startpoint_y+1)||', '||startpoint_x||' '||startpoint_y||'))',26917) as shape
(4) Now, the coordinates look like this (the vertex direction is counterclockwise; vertex 1 and 5 are both 0,0):
(5) This is what the full query looks like:
--create or replace view sdo_geom_grid_polygons_vw as (
select
                 objectid,
                 'polygon(('||startpoint_x||' '||startpoint_y||', '||endpoint_x||' '||endpoint_y||', '||endpoint_x||' '||(endpoint_y+1)||', '||startpoint_x||' '||(startpoint_y+1)||', '||startpoint_x||' '||startpoint_y||'))'        as wkt,
from
with dimension as (
    select 0 as point from dual
        union all
    select level
    from dual
    connect by level <= 10
), points as (
    select
        a.point as startpoint,
        b.point as endpoint,
        c.point as fixed
    from dimension a
    cross join dimension b
    cross join dimension c
    where b.point - a.point = 1
select
    cast(rownum as number(38,0)) as objectid,
    startpoint_x,
    startpoint_y,
    endpoint_x,
    endpoint_y
from
    select
        startpoint as startpoint_x,
        fixed as startpoint_y,
        endpoint as endpoint_x,
        fixed as endpoint_y
    from points
        union all
    select
        fixed as startpoint_x,
        startpoint as startpoint_y,
        fixed as endpoint_x,
        endpoint as endpoint_y
    from points
order by startpoint_x, startpoint_y, endpoint_x, endpoint_y
where
    startpoint_y = endpoint_y --get horizontal lines only
DanPatterson
MVP Esteemed Contributor
Bud
Yeah, that's the source of my query. I mention it in the link in the original post.
Maps-Berlin
