conversion 2D raster to 3D
1145
09-15-2024 09:50 AM
Labels (3)
RakhshindaBano
I am trying to generate a map with a 2D raster as basemap (observed landuse) and overlay it with 3D error bars (containing the incorrect land use categories that model predicted). So it involves conversion of one of the 2D files to 3D first
I have been trying both in arcgis pro and arc scene
  • In Arc Scene I first created a height column in attribute table as the raster doesn't have elevation information. when I tried this link and increased the value of vertical exaggeration, it also changed the 2D base map which I wanted to keep as it is.
    I am looking to get something like the map at the bottom but the vertical bars come from a different raster with the same spatial boundary as base map
    • The python code I have been using looks like below and it gives me a map skipping the basemap completely and very high error bars. I am trying to figure out what am I missing
      import arcpy
      import pandas as pd
      import numpy as np
      import matplotlib.pyplot as plt
      from matplotlib.colors import ListedColormap
      import os
      from mpl_toolkits.mplot3d import Axes3D  # Import for 3D plotting
      # Switch to 'Agg' backend for non-interactive use, better for saving figures
      import matplotlib
      matplotlib.use('Agg')
      # Input file paths
      raster_a_path = r"C:\Users\xyz\ xyz \ xyz \ xyz \ xyz.tif"
      raster_c_path = r"C:\ Users\xyz\ xyz \ xyz \ xyz \ xyz.tif"
      csv_path = r"C:\ Users\xyz\ xyz \ xyz \ xyz \ xyz.csv"
      output_folder = r"C:\ Users\xyz\ xyz \ xyz \ xyz \ xyz”
      # Load the CSV file containing land use types and colors
      legend_df = pd.read_csv(csv_path)
      legend_df['LandUseType'] = legend_df['LandUseType'].str.strip()  # Clean up data
      # Ensure all color codes are valid hexadecimal
      def validate_color(color):
          if isinstance(color, str) and color.startswith('#') and len(color) == 7:
              try:
                  int(color[1:], 16)  # Try converting from hex to RGB
                  return True
              except ValueError:
                  return False
          return False
      legend_df = legend_df[legend_df['Color'].apply(validate_color)]
      # Convert values and colors to a dictionary
      value_to_color = dict(zip(legend_df['Value'], legend_df['Color']))
      # Convert colors to RGB tuples for use with matplotlib, adjust brightness for 3D bars
      colors_rgb = [tuple(min(int(color.strip("#")[i:i+2], 16) / 255.0 * 1.5, 1.0) for i in (0, 2, 4)) for color in legend_df['Color']]
      cmap = ListedColormap(colors_rgb)
      # Load raster datasets
      raster_a = arcpy.Raster(raster_a_path)
      raster_c = arcpy.Raster(raster_c_path)
      # Convert raster_a and raster_c to NumPy arrays
      raster_a_array = arcpy.RasterToNumPyArray(raster_a)
      raster_c_array = arcpy.RasterToNumPyArray(raster_c)
      # Check if dimensions match
      if raster_a_array.shape != raster_c_array.shape:
          raise ValueError(f"Dimensions of raster_a ({raster_a_array.shape}) and raster_c ({raster_c_array.shape}) do not match")
      # Mask NoData values (-9999) in raster_a
      no_data_value = -9999
      raster_a_masked = np.ma.masked_equal(raster_a_array, no_data_value)
      # Adjust extent based on the raster's spatial reference
      extent = [raster_a.extent.XMin, raster_a.extent.XMax, raster_a.extent.YMin, raster_a.extent.YMax]
      # Plot Raster A in 2D
      fig = plt.figure(figsize=(10, 10))
      ax_2d = fig.add_subplot(111)
      img_2d = ax_2d.imshow(raster_a_masked, cmap=cmap, extent=extent, interpolation='none')
      # Overlay Raster C in 3D (vertical bars)
      ax_3d = fig.add_subplot(111, projection='3d')
      # Create grid for raster_c
      x = np.arange(raster_c_array.shape[1])
      y = np.arange(raster_c_array.shape[0])
      x, y = np.meshgrid(x, y)
      # Normalize height of 3D bars to a reasonable scale
      heights = raster_c_array / np.nanmax(raster_c_array) * 10  # Scale heights for visibility
      # Plot each bar as a vertical block
      for i in range(raster_c_array.shape[0]):
          for j in range(raster_c_array.shape[1]):
              if raster_c_array[i, j] != no_data_value:
                  ax_3d.bar3d(x[i, j], y[i, j], 0, 1, 1, heights[i, j],
                              color=cmap(raster_c_array[i, j] % len(colors_rgb)), alpha=0.5)
      # Set aspect ratios and remove the 3D axis, background grids, and labels
      ax_3d.set_axis_off()
      # Set the view angle for 3D projection
      ax_3d.view_init(elev=50, azim=-60)
      # Pause to ensure rendering completes before saving
      plt.draw()
      plt.pause(0.1)
      # Construct the full path for saving the plot
      output_path = os.path.join(output_folder, "output_base_map_with_3D_overlay.png")
      # Save the plot to the specified folder
      plt.savefig(output_path, bbox_inches='tight', dpi=300)
      print(f"Plot saved successfully to: {output_path}")
