Conditional expression for 2 rasters that intersect
966
03-17-2025 08:42 AM
JohnEsch2
I have 2 rasters that intersect vertically:  Fm1Top & Fm2Top. I most cases Fm1Top is above Fm2Top. In small areas Fm2Top has a higher elevation. I would like to build a Conditional expression:
If Fm1Top is greater than Fm2Top, use Fm1Top. If Fm1Top is less than Fm2Top, use Fm2Top
In in other cases I might want to use the above expression and subtract a value (ex 50) from Fm2Top if it is less than Fm1Top.
BrendanNewell
hi @JohnEsch2 ,
Using the Raster Calculator in ArcGIS Pro you can build map algebra expressions using your above logic.
Scenario 1 -  Con("FM1">"FM2","FM1","FM2")
  • if FM1 is greater than FM2 THAN assign a the value as FME1, else assign a value of FM2
Scenario 2 -  Con("FM1">"FM2","FM1","FM2"-50)
  • if FM1 is greater than FM2 THAN assign a the value as FME1, ELSE assign a value of FM2-50
https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/conditional-evaluation-with-...
Give this a test and see if this produces the desired results
