Color Ramp for Stretched Data?
1207
02-21-2023 09:18 PM
DEsmo
Hi, is there a way to make it so that the color ramp displayed in a legend reflects the stretched data of a raster layer? I've noticed that it doesn't change when the stretch type changes. For example, if a stretch is applied that makes it so most of the data is has the middle range of colors, the color ramp in the legend should be showing that. If the color ramp isn't adjusted, it isn't then showing the actual values displayed on the map. This seems like a major issue.
Thanks
DanPatterson
MVP Esteemed Contributor
What version of Pro you are using?
BUG-000115963: Difference in display of symbology between the color.. (esri.com)
... sort of retired...
oakleafy
I'm having the same issue. I seriously can't believe they simply decided to not fix this bug 😩 I guess I'll try this in QGIS instead...
