Clustering points
1691
06-16-2022 07:10 AM
SLouq
by MVP Alum
I have a 60 points which represent buildings which I want to display on a map. Some of the points are on the same street and in some cases right next to each other which makes it difficult to read on a map. I thought maybe if I could cluster some of these points together then it would make the map easier to read. I added an Index field to may table with letters to represent each point and created an index in Excel to hold the labels for each point. Clustering would be the answer to hold all the points close to each other in one point in the map but once you have 5 or 6 points clustered under one point, how do you expand the point to reveal the other points held in the cluster?
I read in version 2.9 their is a symbology option to do this but I still have 2.8 on my computer. How can I do this in version 2.8?
Thanks
JayantaPoddar
Could you check if Disperse Markers (Cartography) addresses your concern better than Clustering?
Think Location
JayantaPoddar
Think Location
SLouq
by MVP Alum
JayantaPoddar
Thank you
