clipping linear tracks
1096
08-28-2019 04:23 AM
MarkBalman
Hi all
I have an issue when trying to clip linear tracking data with a polygon area of interest. The problem is why in some cases, the tracks I am clipping end up with vertices at all linear intersections  which is not what I want, and in some cases, I have tracks ending up with millions of vertices. This is easier to see in the following graphics:
Unclipped track:
unclipped
Clipped track:
clipped
So, my question is how to stop these additional vertices from being added (or is this something inherent in the geoprocessing algorithm and I have to live with it)
I could of course manually edit these tracks but this will be massively time consuming.
Any ideas would be gratefully received, unfortunately I cannot share this data.
Best regards,
Mark
Tags (1)
KoryKramer
Esri Community Moderator
Have you looked at the pairwise tools? Pairwise Intersect—Help | ArcGIS Desktop   I haven't worked with these a ton but I recall them giving different output because they work differently from some of the other analysis tools.
MarkBalman
Hi Kory,
Many thanks for the suggestion - alas, this still produces vertices where the lines intersect.
Will keep looking for a solution.
Best wishes,
Mark
