Clip tool not working for feature layer
2599
10-05-2023 02:42 PM
StasiaPietraszun
I am trying to clip a feature layer in ArcGIS Pro with the clip tool and usually I have no issues. It is only with one of the attributes for the feature layer that is not working. I've tested it on other attributes in the same layer and the tool works. I read somewhere that if the area is too big then clip will not work? I am thinking this could be the issues. Wondering if anyone has any suggestions in how to fix the problem. Thanks.
DanPatterson
Show an image of what you are clipping and what you are using to clip it.  The geometry needs to overlap and preferably be in the same coordinate system.  Also, if you are having issues, start with fresh copies in a locally stored file geodatase
... sort of retired...
