Clean up DTM from modern features
2032
7
03-08-2023 04:24 AM
Labels (2)
BenFx
Hi, in order to get a premodern DTM, I want to clean the ASTER GDEM from anthropogenic features. To do this, I have compiled the vector data of modern features and want to extract them from the DTM. The result should be a perforated DTM. However, Extract by Mask and Clip Raster (Use input features for clipping geometry) provide me the rasterised modern features and not the perforated DTM.
How can I obtain a perforated DTM with No-Data-Holes? I have not found a suitable answer elsewhere in the forum...
Many thanks in advance - Ben
DanPatterson
MVP Esteemed Contributor
that is what SetNull does
... sort of retired...
DanPatterson
Are you attempting to set those areas to Null?
Set Null (Spatial Analyst)—ArcGIS Pro | Documentation
since you can't recover the dtm values premodern values from an existing  dtm
BenFx
You might be on to someting. I'll give it a try. Thx for the fast response
BenFx
I assumed that setting the modern, rasterised features to Null might help, but it didn't.
BenFx
Basically, I want to perforate a raster layer with a vector layer. The vector layer features should be cut out of the raster and leave a raster with void gaps.
DanPatterson
BenFx
Thank you very much for your patience,  Dan 🙂 I will wrap my head around it
BenFx
The reason why Set Null did not output a correct perforated raster was due to an unsuitable file format.
I rasterised the compiled vector layer by using Extract by mask. The output was reclassified and exported to TIFF. Also the DTM was exported to TIFF. Only then was a perforated raster achieved. All previous attempts with FGDBR produced incomprehensible results.
Thanks again 🙂
