clean uninstall/reinstall of ArcGIS Pro
2534
02-03-2022 04:05 AM
Hala_Ghareeb
Hi all,
How can I do a clean uninstallation /reinstallation of ArcGIS?
Thanks in advance.
Tags (1)
DanPatterson
MVP Esteemed Contributor
Robert_LeClair
Esri Esteemed Contributor
Once you uninstall ArcGIS Pro, I've found it useful to rename the ESRI folder in the C:\users\<user profile>\appdata\local and C:\users\<user profile>\appdata\roaming to ESRI_OLD before I do a clean install of ArcGIS Pro.  Seems to help the stranger issues seen...
AhmedTarekAlhusainy
Hi Hala, I wish you all the best. Here is you can find the best way to do this
https://esriaustraliatechblog.wordpress.com/2023/01/18/performing-a-clean-uninstall-of-arcgis-pro/
good luck
