Chart data not updating with Table updateConnectionProperties method
1645
02-19-2024 07:27 PM
ColinLindeman
When I use the function layer.updateConnectionProperies in the Python View in an ArcGIS Pro Project on a Table that has a broken data source, it and its Chart are updated with the new data source.
When the same function is run in a standalone script that exports a pdf file from a Report that contains a Supplemental Page with a Layout that contains the Table and Chart, the Table updates but the Chart does not.
I'm trying to figure out how to get that Chart to update so that my Report can be reused in different ArcGIS Pro Projects with different Databases.
ColinLindeman
As a workaround it seems that toggling one Chart's visibility to off, then on, then exporting the Report to PDF will update all Charts to their Tables' new data source in the PDF.
ColinLindeman
Unfortunately this workaround is not working when the tool is run from the ArcGIS Pro Project GUI.
ChristopherAllen
Hi @ColinLindeman ,
The chart should automatically update when the data source is changed regardless of the environment. Unfortunately, I was unable to reproduce the problem you're seeing. I created a standalone script to update a layer's connection properties and export the report (with a supplemental page that includes a layout with the chart) to PDF. The chart was updated with the new data source in the PDF.
I'd appreciate if you're able to share any other details about your specific workflow. In my script I was setting the data source to a layer stored in a File GDB, but perhaps your data is stored differently? If you're able to share the script and/or project you're using, please feel free to send to [email protected].
Thanks!
Chris
ColinLindeman
Hi Chris, I am using SQL Server 15.0.2000 Databases. I will send you the scripts.
