capsule symbol
1948
03-01-2024 05:40 AM
pinisolomon1
hi,
I'm using ArcGIS Pro to create a custom dictionary symbology for my app.
I'm trying to create a longer capsule, my findings were always scaling the capsule in height and width together. I want to keep the rounded edges but make it longer.
An even better option would be that the length could be controlled from the custom dictionary so I can change the length during runtime (and primitive overrides)
pinisolomon1
the casule picture is the original capsule symbol from arcgis 2d
the second picture is what I'm trying to achieve ... currently I did it with 3 symbols 2 capsules and one rect. in the middle
Amir-Sarrafzadeh-Arasi
Dear Pinisolomon,
I hope you are doing well,
If you want the capsule being dynamic, you can make the size of the capsule dynamic, which will increase the size of the symbol, I mean it will enlarge the width and length together,
so a good approach can be, you can define for example 3 different symbols in your dictionary and then based on an attribute select one of them .
Please check the below links:
https://github.com/AmirSarrafzadeh/symbology_dictionary
https://github.com/Esri/dictionary-renderer-toolkit/blob/master/docs/working-with-overrides.md
https://github.com/annelfitz/annelfitz.github.io/tree/master/dictionaryRenderer/symbolService
Let me know if you need more info
Amir Sarrafzadeh Arasi
