Cant Open Existing Files in ArcGISPro 3.0
5964
11
06-27-2022 03:39 PM
BHunt1327
I just upgraded to ArcGIS Pro 3.0 and now I can't open existing files created in 2.9. Any help would be appreciated.
2 Solutions
MGT8C2U
Updating the Microsoft Access Database driver solved all of my issues with this. Link to solution below:
https://community.esri.com/t5/arcgis-pro-questions/arcpro-v3-amp-exceltosqllite64-performance/m-p/11...
BlažGolob
Thanks, this works for me. I just update Microsoft Access Database driver: (https://pro.arcgis.com/en/pro-app/latest/help/data/excel/prepare-to-work-with-excel-in-arcgis-pro.ht...).
B.R.
Blaž
BlažGolob
Neither do I. I can open small project created in Pro 2.9 with 1 database connetion, but project with more conncetions just loadings map forever.
Best reqards.
MGT8C2U
Same here.  I can get a few to open, but many others will not.
MGT8C2U
This has now become a big issue for me.  Is there any information out there about it?
Andrew--Johnson
This kind of issue needs to be looked at by a technical support analyst. Please open a case with them through the contact link here https://support.esri.com/en/contact-tech-support
Please provide as much details as you can about your installation as well as which projects seem to be affected. They can do a screenshare with you to investigate further.
thanks,
Andrew
BHunt1327
Thank you. I did that and the issue is resolved. The problem was the Microsoft Access Database driver.
RobbieRotten
I am also unable to open any of my existing workspaces in ArcGIS Pro 3.0.
Runs through the 'upgrade' phase then gets stuck in an infinite 'loading' loop.
Have run ArcGIS Pro in administrative mode and allowed the loading phase to run for over 24 hours with no change.
RobbieRotten
Turns out I simultaneously had Microsoft Access Database 2010 and 2016 installed.
Uninstalling both and reinstalling 2016 appears to have solved the issue.
MGT8C2U
BHunt1327
Thanks that worked for me also!
