Cant add field to shapefile feature class in arcgis pro
2100
03-19-2022 01:38 PM
GaryThomann
Trying to add a field to shapefile feature class.  Field type is text.  When I save the changes the feature class data just disappears and there is a ! in front of the class name.  If I delete the feature class and then try to bring the shapefile in again I get the message "Number of shapes does not match the number of table records."  The shapefile dbf file is the only thing that was changed when I tried to do the original field add.  Any ideas?
DanPatterson
MVP Esteemed Contributor
The dbf wasn't edited outside of Pro was it?
Any chance a row was deleted by mistake?
I would try to copy the shapefile into a geodatabase to recover as much of the data as possible, as a first step, then report what is missing after the process
... sort of retired...
DanPatterson
GaryThomann
Thank you Dan.  No the shapefile was not edited outside Pro.  After the shapefile got changed by trying to add a field, I tried to add the shapefile into a database.  I immediately got a message "Internal error initializing expression" and it did not load.
GaryThomann
I took the original shapefile and first loaded it into a database.  Then I added the field.  That seems to work.  Thank you for the suggestion.
DanPatterson
glad it worked out
