Cannot set breakCount for 'ManualInterval' symbology
1880
01-30-2019 09:23 AM
OliverCoudert
Hello,
I am unable to set the BreakCount for 'ManualInterval' symbology.  The value remains zero.  What is the proper way to set the number of breaks?
It works for 'NaturalBreaks' classificationMethod but not for 'ManualInterval'.  Changing the classification method in the code below and removing the references to classBreaks will work as expected.
#ArcGIS Pro 2.1.2
#Python 3.6.2, 64 bit
aprx = arcpy.mp.ArcGISProject('CURRENT')
cwd = 'c:\\temp'
workingLayer = aprx.listMaps()[0].listLayers()[0]
sourceTable = arcpy.ListTables()[0]
sourceLayout = aprx.listLayouts()[0]
metric = ('Calc01Perc',(-0.5,0.5)) # (Field name, (min,max values))
sym = workingLayer.symbology
sym.updateRenderer('GraduatedColorsRenderer')
sym.renderer.classificationMethod = 'ManualInterval'
sym.renderer.classificationField = sourceTable + '_' + metric[0]
print('DEBUG   fieldname: ' + sym.renderer.classificationField)
sym.renderer.colorRamp = aprx.listColorRamps('Bathymetric Scale')[0]
sym.renderer.breakCount = 10 # This does not stick for 'ManualInterval' or unspecified classificationMethod
print('DEBUG   breakCount: ' + str(sym.renderer.breakCount) + '= 10 ?')
step = 0.1
breakVal = -0.5
print('DEBUG   len(classBreaks) = ' + str(len(sym.renderer.classBreaks)))
for brk in sym.renderer.classBreaks:
    brk.upperBound = breakVal
    breakVal += step
    print('DEBUG   next break: ' + str(breakVal))
workingLayer.symbology = sym‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
OliverCoudert
OK, I figured it out.
Selecting the Manual Interval classification does not do anything.  I suppose you can read it, but you cannot set it.  So, per the documentation, to manually set class breaks, you must start with one of the standard classifications and make adjustments as needed.
In the code below, I set the classification method to equal interval and set the number of desired breaks.  I then overwrite each of the breaks.
fieldName = 'Shape_Area'
sym.renderer.classificationMethod = 'EqualInterval'
sym.renderer.classificationField = fieldName
y = 0.3
x = y/10.0
    print(str(i) + ': ' + str(x))
    brk.upperBound = x
    brk.label = '\u2264' + str(round(x,3))
    x = round(x + (y/10),3)
OliverCoudert
y = 0.3
x = y/10.0
    brk.upperBound = x
MityaKletzerman
Hi! Are the labels really being rounded with this script?
