Cannot Animate NetCDF File from Multidimensional Raster Layer
1253
03-28-2023 12:52 PM
imcgon
Hello! Thank you in advance helpers,
I have a NetCDF file with 3D arrays dependent on dimensions {time, y, x}. When I use the tool Add Data > "Multidimensional Raster Layer" it is able to see the array and that it is dependent on time.
Additionally, in the source it can still see the time dimension and the values it contains
However, when plotting it only shows the first time step (i.e. time=1, all the values are 0) and does not expose the play bar to animate the raster across time.
Does anyone have any ideas as to why ArcGIS is not allowing this raster layer to animate across time?
I have attached the NetCDF file in a .zip for reference.
DanPatterson
MVP Esteemed Contributor
Is this what you are following
Multidimensional tab—ArcGIS Pro | Documentation
... sort of retired...
imcgon
Yes, I am hoping to be able to use the Multidimensional tab, but after loading in the layer it is left blank. I am not sure why my data is not being populated into these fields?
