Cannot add field
51920
32
12-04-2017 10:01 AM
IanBrown1
I cannot add a new field column to my attribute table. It is greyed out in all menu areas.
Tags (1)
IanBrown1
Basic Desktop Licence*
DanPatterson_Retired
OMG copy the shapefile to a geodatabase using the Copy Features tool see if that works.
They need a 'Bugs' page in GeoNet
And it is only Monday
IanBrown1
Yup that works!
Haha they really really do need that... I can't bill these hours in good conscience!
KoryKramer
Esri Esteemed Contributor
Dan and Ian Brown‌ I'd recommend searching for bugs on support.esri.com
BUG-000101840: Unable to add fields via the New Field feature for s..
This one is out there and discoverable in a search.
Hope that helps in the future!
I limited my search to the last year... grief...  but still a BUG list by number would be nice, just chronologically added... call it 'issues not addressed' then move it to 'issues addressed' when done
BrianWade
Yup, I also found this Bug?, tried it repeatedly but no joy, I finally used the add field tool to get r done.
p.s. Is there a limit to how many tools can be added to the Quick Access Bar? I would like to add the Add field tool to the Quick Access Toolbar.....
KoryKramer
Have you tried and not been able to add it to the QAT?
Not sure there is a built-in limit, but there may be a practical limit (like how many icons actually fit across your screen).
You might find this interesting: ArcGIS Pro: Ribbons, Toolbars, and UI Hacks | ArcGIS Blog
BrianWade
Yup, it looks like you can only add tools to the QAT from the edit-tools, not the Analysis-tools, or directly from the geoprocessing Toolboxes either, using right click.
After reading your above link in the ArcGis Blog, I'm continuing to see if I can do this, I could be miss something obvious.
KoryKramer
You're right, you can't add the gp tool to the QAT. But you can add the Add Field from the Table > View ribbon.
BrianWade
Nice, exactly what Im looking for, but then the "Bug" bites me!
Its all greyed out? what am I missing?
How do I add the new field?
help?
