cann't create space time cube
1707
01-06-2018 02:13 AM
YUYANG
I ran the space time cube,but it always show the wrong message.
File "<string>", line 1, in <module>
File "d:\arcgispro\pro\Resources\arcpy\arcpy\stpm.py", line 171, in CreateSpaceTimeCube
raise e
File "d:\arcgispro\pro\Resources\arcpy\arcpy\stpm.py", line 168, in CreateSpaceTimeCube
retval = convertArcObjectToPythonObject(gp.CreateSpaceTimeCube_stpm(*gp_fixargs((in_features, output_cube, time_field, template_cube, time_step_interval, time_step_alignment, reference_time, distance_interval, summary_fields, aggregation_shape_type, defined_polygon_locations, location_id), True)))
File "d:\arcgispro\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError:
File "<string>", line 1158, in execute
File "D:\ArcGISPRO\PRO\Resources\ArcToolbox\Scripts\SSCube.py", line 90, in __init__
self.__initialize(cubeObj)
File "D:\ArcGISPRO\PRO\Resources\ArcToolbox\Scripts\SSCube.py", line 136, in __initialize
self.dataset = NET.Dataset(self.path, self.mode)
File "netCDF4\_netCDF4.pyx", line 1811, in netCDF4._netCDF4.Dataset.__init__ (netCDF4\_netCDF4.c:12631)
OSError: Permission denied
Failed to execute (CreateSpaceTimeCube).
DanPatterson_Retired
You need to show a screen grab of your inputs to the tool since it is unclear what they were or whether they were appropriate for the requirements.
As for permissions, are you working with locally stored data for which you have access to the reading and saving locations? or did you try to use data load/save locations on a network or remote location.
YUYANG
Dan,
thanks for your reply.I found the reason why I failed. It seems that ArcGIS PRO 2.0 didn't support chinese path. When I changed the save path in English, it successed.
