Can the new clause be automatically filled in the operators and fields of the above clause?
888
8
04-17-2020 12:43 AM
圈圈
DavidPike
MVP Frequent Contributor
I might be misunderstanding, your question isn't clear, but the 'where' is a sql statement which is only specified once.
the rest is accomplished with and/or statements.
圈圈
Yes, I didn't make it clear before. I mean, every time I create a new clause, I have to manually select operators and fields. I want to be able to automatically fill in the operators and fields of the above clause. Does ArcGIS Pro provide this method?
DanPatterson_Retired
You can save expressions and reload them... see the disk and folder icons above the check mark on your image.. they are for saving and loading expressions
圈圈
Because I often need to enter different expressions, using saved expressions is not suitable for me.
Then there are no other options.
圈圈
Thank you anyway.
DavidPike
Sorry for misunderstanding. I think there's a toggle button to switch from interactive to manual entry. I'll have a check
圈圈
You are right, there's a toggle button to switch from interactive to manual entry. That's good for pasting SQL expressions from the clipboard, but I often need to enter different expressions.
