Can't select poly from layer when symbology not defined
1397
12-18-2019 04:50 PM
GabrielMarcus1
I recently edited a poly FC. When halfway done, I imported symbology from another layer to help me guide how my edits were coming along. I had "show values out of range" on initially, but turned it off because it was distracting. After turning it off, I noticed I wasn't able to select any polygons that were out of range. I could select the polygons that had symbology defined.
Is this normal behavior, or should I report a bug?
I'm using Pro 2.4.2.
JacobHelfman1
It looks like you should try adjusting the symbology by clicking More > Refresh Values per the 3rd bullet point here: Graduated colors—ArcGIS Pro | Documentation. Otherwise, I would try to experiment with the Symbology pane, using othe methods: Symbolize feature layers—ArcGIS Pro | Documentation.
GabrielMarcus1
Jacob,
Thanks for the response. I was creating and editing a FC and most of the symbolized attributes were null at the time. I know how to fix this issue, I just didn't recall symbology behaving in that manner. My question was more of "is this normal" versus how to fix it. I guess the answer is "yes".
Thanks again!
Gabe
