Can't select multiple features in map
9277
13
10-04-2021 12:03 PM
JoeBorgione
Using ArcGIS Pro 2.7.4, I cannot interactively select multiple features in a map.  When I hold the shift key down with the select tool selected it zooms in.  Is there a hot key setting I need to turn off?
In my gif below, I select one street segment, clear the selection and then select the adjacent segment and clear. Then with the first segment selected, I hold down shift and when I try to select the second segment, it zooms in.ShiftNoWorkee.gif
That should just about do it....
wayfaringrob
Honored Contributor
@JoeBorgione  Do you have Webroot antivirus by chance? In our organization, the identity shield setting was causing some bizarre issues with the cursor and the select/zoom/navigate tools.
Info: https://community.esri.com/t5/arcgis-pro-questions/uncontrolled-zoom-out-on-layout-view-arcgis-pro/m...
JoeBorgione
Thanks for the reply, @wayfaringrob but alas we don't deploy Webroot.  The post you link above mentions a bug, but that was in ArcMap.
DanPatterson
MVP Esteemed Contributor
Joe, you don't have the Explore tool active by mistake, since that does a center zoom in.
shift with the Selection tool should do what you want, but have a read of the shortcuts
ArcGIS Pro keyboard shortcuts—ArcGIS Pro | Documentation
... sort of retired...
JoeBorgione
It seems to be a computer specific problem;  it works as expected on my laptop.  The past few weeks with ArcGIS Pro have been brutal.  I've uninstalled and downgrade, upgraded (and repeat) several times and keep finding new problems.
But as I like to say:
AndyWells
I am also having this same behavior. The explore tool is definitely not enabled. If I move the arrow over the feature I am selecting, hold shift and do not move the mouse at all, I can select without zooming in. But if I move the mouse even a tiny bit, the zoom rectangle appears. Very frustrating.
wayfaringrob
Honored Contributor
One of my colleagues is having similar issues with explore/select/zoom tools just in the last few weeks - wonder if something broke.
by Anonymous User
Not applicable
Same issue here from time to time. Restarting my computer seems to fix it for me.
WillPlatt
I just had this issue happen to me.  I clicked back over to Explore then clicked back to Select and that seemed to fix it.
MylesTryder
Thanks for the tip! I just had the same problem, and this fixed it for me
