Can't install 2.8
8953
12
06-02-2021 09:22 AM
Brian_Wilson
Honored Contributor
When I attempt to install ArcGIS Pro 2.8 from either starting the MSI or from the command line, I get
"You must accept the EULA to install ArcGIS Pro"
...and yes, of course, I tried both checking and not checking the box "I accept the Master Agreement" and on the command line using "ACCEPTEULA=YES" and various others like "ACCEPTEULA=1".
I am jealous of people reporting problems here with 2.8 since they seem to have been able to install it.
This is the command line I am using
msiexec.exe /i ArcGISPro.msi ACCEPTEULA=YES /qb
RichardDaniels
MVP Regular Contributor
This same issue happens with ArcGIS Pro 2.8 to 2.9 upgrade. Core issue can be two fold, left behind registry setting from ArcGIS Pro uninstaller OR there is a clone of the default Conda (Python) environment. ESRI recommended that Pro users not modify the default environment, so a user needs to clone  if they want to install any additional Conda packages -e.g., deep learning modules.
In regards to registry settings, we found that under Installer related settings under the apps GUID, {26C745E6-B3C1-467B-9523-727D1803EE07} were left behind. When these 3 settings were deleted the installer for the next higher version worked.
Cond environment removal information at Delete an environment—ArcGIS Pro | Documentation
Lkoman
Hello
Can you please provide the full location of this registry key that you delete?
Laurene Koman
ArcGIS Install Team.
RichardDaniels
Look under:
HKEY_CLASSES_ROOT\Installer\Products\6E547C621C3BB764593227D78130EE70
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\6E547C621C3BB764593227D78130EE70
Note after uninstall of 2.8 at least one of these registry settings remained, it might be easier to search for ProductName='ArcGIS Pro' to find it and then delete.
HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro is also there, it references Python.
