Can’t display classified raster in ArcGIS Pro 3.3
6733
16
06-11-2024 04:22 PM
LizLotz_mc2
For some reason I can’t display an raster elevation DEM layer in ArcGIS Pro 3.3 using the Classify symbology.  It displays without a problem using the Stretch symbology, but when I select “Classify” instead, it immediately starts “Generating unique values” which runs for awhile.  Then, I get an error.  I tried increasing the number of values in Options up to 100,000,000, but I still get the error.  And, the Statistics don’t show up in the Symbology Pane.  The Statistics are shown in the Layer Properties however.  See the screenshots below.
When I do the same thing in ArcMap 8.2, I can select the the Classified display and specify the # of classes and class breaks for display, and view the histogram and statistics.
Why is this simple raster display a problem in ArcGIS Pro??
GeneratingUniqueValues.JPGDEM_8_Symbology_Classify_Error.JPGDEM_8_RasterProperties_AGP.JPGDEM_8_Raster_Classify_ArcMap.JPG
CorrineCoakley
I had high hopes, but nope, it isn't fixed.  This makes it seriously difficult to symbolize multiple NDVI rasters with scientific values  from -1 to 1. ArcPro won't let me set those class limits because I don't have values that go all the way to -1.
ricardoaravena
This bug didn't exist in 3.2. How is it that ESRI is including bugs in their updates?
Now I have to uninstall and roll back.
adminJDN
@Robert_LeClair
BUG-000167647: ain't fixed.
Still broken in 3.4
LizLotz_mc2
That is disappointing!  I had hoped this would be fixed as planned at 3.4.
Robert_LeClair
Esri Esteemed Contributor
I'm looking at the Esri Support Services internals for BUG-000167647 and it shows fixed at ArcGIS Pro 3.4 although from your message it appears not to be fixed.  The workaround at 3.3 was:
  • Use the Apply Symbology From Layer tool to import the symbology from a similar layer.
  • Edit the 'Maximum number of unique values to display' parameter within the Raster and Imagery ArcGIS Pro options.
I'd recommend reaching out to Esri Support Services to create a case for the analyst to investigate.
adminJDN
I need to correct myself. Sensu strictu, the bug has been fixed. It is possible to use Classify renderer for single band in v3.4.
Although there is no backward compatibility with projects created earlier (v3.1)
LizLotz_mc2
Thanks for clarifying
