can't delete temporary layer in Python
4137
12
10-24-2024 12:16 PM
PaulCone2
I have temporary layer that I'm creating in a Pro Notebook.
arcpy.MakeFeatureLayer_management(boec, r"memory\boecFL")
Once I'm done processing, I'm attempting to delete it, but I get an error message.  If I manually delete it, it works, but then when I copy that from the History as a Python snippet and try and run it, it fails.
arcpy.management.Delete(
in_data=r"memory\boecFL",
data_type="GPFeatureLayer"
WARNING 000110: memory\boecFL does not exist
I've tried various permutations for in_data and data_type.  Running Pro 3.1.7.  What am I missing?
PaulCone2
Because that's what Copy Snippet gave me.  I took it out and it works.  Seems like a common thing that Copy Snippet doesn't match what you should actually do in your code.  Anyway, thank you everyone for the help.
JoshuaBixby
MVP Esteemed Contributor
Huh, interesting.  It may be a defect in the Copy Snippet functionality.  I am glad it is working for you now.
PaulCone2
I'm still here!  Will give it a try.
