can't delete temporary layer in Python
4129
12
10-24-2024 12:16 PM
PaulCone2
I have temporary layer that I'm creating in a Pro Notebook.
arcpy.MakeFeatureLayer_management(boec, r"memory\boecFL")
Once I'm done processing, I'm attempting to delete it, but I get an error message.  If I manually delete it, it works, but then when I copy that from the History as a Python snippet and try and run it, it fails.
arcpy.management.Delete(
in_data=r"memory\boecFL",
data_type="GPFeatureLayer"
WARNING 000110: memory\boecFL does not exist
I've tried various permutations for in_data and data_type.  Running Pro 3.1.7.  What am I missing?
Dave_Magill
I've edited the following post -- per JoshuaBixby below, if MakeFeatureLayer always creates an in memory layer, leaving 'memory/' out of the out_layer parm seems to fix the problem.
The following is another way to delete, but deletion by name works for me if leaving out 'memory/' in MakeFeatureLayer and Delete functions
Guessing OP has moved on, but for what it's worth, the following works for geoprocessing in a standalone script not tied to a map or Pro:
mflResult = arcpy.management.MakeFeatureLayer(in_features=yourFeatClass,out_layer="aLayer")
-- later --
arcpy.management.Delete( mflResult.getOutput(0) )
DanPatterson
MVP Esteemed Contributor
it is deleted when the application is closed, as per help topic
and it should be deleted as soon as possible within your script, not after it has run, since references to it will be lost when the script finishes and the application is still open
Write geoprocessing output to memory—ArcGIS Pro | DocumentationWrite geoprocessing output to memory—ArcGIS Pro | Documentation
... sort of retired...
PaulCone2
Nah, it puts it in the TOC, and I attempt to delete it pretty soon after.  When I close the project and reopen it, it's still there.
print("Making feature layer from " + boec)
toc = time.process_time()
print("Making feature layer process time = " + str(toc - tic))
tic = time.process_time()
print("Selecting features from " + r"memory\boecFL" + " for " + expression)
arcpy.SelectLayerByAttribute_management(r"memory\boecFL", selection_type="NEW SELECTION", where_clause=expression)
print("Selecting features process time = " + str(toc - tic))
print("Inserting features from " + r"memory\boecFL" + " into " + outputFC_FM)
fcInsert(uidPreValue="BOEC", lookupValue="BOEC", featureLayer=r"memory\boecFL") ### Call the main fcInsert function
print("Deleting in memory feature layer")
data_type=""
PeterKnoop
MVP Regular Contributor
Make Feature Layer produces a feature layer, rather than a feature class, so out_layer cannot be directed to the "memory" workspace.
Your call to MakeFeatureLayer is actually creating a feature layer that ends up with the name of "memory\boecFL".
If you examine the Properties for "memory\boecFL" in your table of contents, then you should see under Source that its Data Source is the original boec feature class from which it was derived, rather than a feature class named boecFL in the memory workspace.
You'll note the documentation for Make Feature Layer states, "The [output] layer that is created is temporary and will not persist after the session ends unless the layer is saved to disk or the map document is saved." I suspect this wording is a holdover from the days of ArcMap, and needs updating for Pro.
In Pro, the temporary output layer generated by Make Feature Layer is persisted when you save your project. So the only way to not persist the layer is to close Pro without saving your project, after you've run Make Feature Layer.
(Side note: depending on what your goal is here, the SelectLayerByAttribute step may be extraneous. You can specify an expression directly in MakeFeatureLayer. In which case the resulting temporary layer would be ready for your insert step as-is.)
PaulCone2
Thank you, this is helpful.  My goal is to get rid of the extra layer and symbology that is junking up the map, and not the data behind it.
The expression is built in some code prior so I think it would be unwieldy to put it directly in the MakeFeatureLayer call.  Here's the entire code block...
#region insert BOEC data
print("** Inserting data from BOEC source layer ** ")
boec = inFC
expression = "{} IN ('FRVW', 'GRSM', 'MULT', 'MYDP', 'PORT', 'TRO', 'WVLG')".format(arcpy.AddFieldDelimiters(r"memory\boecFL", "AGENCY"))
data_type=""
print("Inserting fields process time = " + str(toc - tic))
#endregion
PeterKnoop
You can remove the layer MakeFeatureLayers is creating using the removeLayer method for your Map.
Dave_Magill
-- later --
JoshuaBixby
The inclusion of "memory" in the layer name makes me think the OP is trying to create something in an in-memory workspace.  Make Feature Layer always creates a temporary layer, and that layer is not stored in an in-memory workspace.  The Delete tool likely is looking in an in-memory workspace given the path passed, and since feature layers aren't stored in an in-memory workspace, nothing is there to delete.
I think the tools are not being used correctly, which is causing confusion for them.
PaulCone2
Whatever it does, it adds it to the TOC, so I want it out of there by the end because it's confusing to have it there.
JoshuaBixby
Why are you prepending "memory\" to the name of your layer?  That is likely confusing the Delete tool.
