Can not create a project
2699
6
06-18-2023 06:11 AM
SamehLamada
Hello everyone,
i hope that someone may provide me with help regarding this problem, i cannot create a project on my local computer Screen Shot 6-18-2023 at 3.57 PM.png
i know i can choose another location offcourse and it works, but what if i want to use the default location on document folder
appreciation and thanks to whom who may concern
DanPatterson
MVP Esteemed Contributor
assuming that is your user space, are there any spaces or punctuation in your user name?
... sort of retired...
SamehLamada
no space or punctuation in the user name.
MapGrrl
I second this suggestion. Is there a SPACE at the end of the path name? or at the end of your Project Name?
Have you tried using a different Project Name?
SamehLamada
no space and yes i tried to use different name with the same situation " the location is invalid please choose another location."
DanPatterson
Well if you have full control of your machine and not in some controlled environment, choose a new default location because it doesn't like where you want it to go, or it can't save there for some reason
DanielFox1
Hi @SamehLamada
Are you able to make a folder in your C Drive called "Test" or "Temp" just as a test and create a new project pointing the pathway to the new folder in the C: Drive?
If you are still getting the same error message I would recommend a clean uninstall of ArcGIS Pro and reinstall a fresh copy from MyEsri to see if this makes a difference.
Performing a clean uninstall of ArcGIS Pro
