Can export subnetwork run on a read only database or does it require an editable database
425
09-17-2025 07:24 AM
LouEarly
Can export subnetwork run on a read only database or does it require an editable database.
Understanding that if a setting is set that would cause an edit, it will fail if the DB is readonly.  I am curious if all settings that would cause an edit are off, should the export run successfully on a read only DB?
