Can custom vector tile style of arcgis basemap be added to arcgis pro or arcMap?
1193
08-17-2022 08:15 PM
baohuachu2
I customized "arcgis-streets" using vector tile style editor .  The editor out put is the style json file. Can arcGIS pro or arcMap load the style json file to add the customized basemap?
MarkBockenhauer
Yes, in ArcGIS Pro you can add the vector tile layer that you saved using the vector tile style editor.   Click Add Data and you should be able to find the vector tile layer that you created in 'My Content'.
MarkBockenhauer
baohuachu2
It works in ArcGIS Pro.  Thanks so much.
In arcMap(10.8), the web map(with one vector tile layer) is added but not displayed.  As the screenshot below.vector tile issue.jpg
