Callout problems
2922
8
01-10-2019 12:48 PM
BrianBulla
Honored Contributor
I have a callout on my page that is too wide.  Is there a way to control how wide it gets, and then spread the text over multiple lines??  This is labelling, not annotation.
AdrianWelsh
MVP Honored Contributor
It may be related to a map series, I don't know. Do you have Maplex Label Engine turned on?
StephenM
Stack labels might be what you're looking for.
stack label location in ArcGIS Pro
BrianBulla
Honored Contributor
Interesting....I don't seem to have that option.  I'm running ArcPro 2.2.4.  Is there a setting I'm missing somewhere to enable this??
AdrianWelsh
Brian,
Are you labelling a feature or is this free text from a text box?
BrianBulla
Honored Contributor
This is feature labelling.
BrianBulla
Honored Contributor
Here are my settings for the Callout:
And when I go to the Positions settings there is nothing there for Stack:
It has worked before though.  I remember seeing Callouts stacked in a previous project.  This one is using a Map Series.  Would that make any difference??
AdrianWelsh
BrianBulla
Honored Contributor
Ah, you're a genius!  With the multiple 'Maps' in my project, some had it turned on and others didn't.
Thanks!
AdrianWelsh
No problem! I'm glad it worked out. Labelling is tricky as there are too many variables to consider! Maplex is another one of those things that throws me for a loop all the time.
