Calculation Attribute rule not working Properly in FGDB
2366
08-15-2023 08:04 AM
Labels (3)
HarishKV
I want to write an attribute rule to add a value to the attribute field if the feature is intersecting with other layer. Both are polygon layers and I had written an arcade expression but it is not returning any result as expected. Below is the expression
var intersectingFeatures = Intersects($feature, FeatureSetByName($datastore, "SurveyPlot2"));
if (Count(intersectingFeatures) > 0) {
$feature["rule"] == "1";
} else {
$feature["rule"] == "0";
return $feature;
Can anyone help me debug the issue
2 Solutions
SarahRijneke
Depends on which app you're using. You can set up arcade calculate expressions in Field Maps Designer that should produce the same results when adding new features to a feature service.
HarishKV
Thank you Sarah. I had nailed it out. Its working fine both in WebApp and FieldMap.
SarahRijneke
Assuming you are running your calculation on an attribute named rule:
return "1";
} else {
return "0";
HarishKV
Thank you Sarah. Do this rule work in the Work with Web App as well.
SarahRijneke
HarishKV
