Calculating slope change
3596
03-14-2022 08:47 PM
SMangum
I need to find areas of rapid slope change greater than 10º.
I created a slope layer from a DEM.
If I create another slope layer from the original slope layer will I get the change in slope angles between adjacent cells (i.e. the slope of the slope between cells)?
Then I would simply run CON (spatial analysis) or RASTER CALCULATOR to isolate areas of slope change >10º, right?
If not, can anyone tell me how?
I'm using ArcGIS Pro version 2.9.1
DanPatterson
MVP Esteemed Contributor
curvature would have the dem as input.
noisy data... depends, you could always run a focal mean over the dem to smooth some of the irregularities if you feel they are present.  Experiment
Surface parameters... Surface Parameters (Spatial Analyst)—ArcGIS Pro | Documentation
why not have a run through, it might be revealing to look at the results as well
... sort of retired...
DanPatterson
SMangum
Huh! I think that's exactly what I need. You're a genius!
If I understand correctly, the input raster would be my DEM_Slope raster. Or am I confused here?
And what constitutes noisy data and how do I know if I have it? High resolution?
My cell size is 10mX10m. Is that high resolution? And if so, should I try the SURFACE PARAMETERS tool instead?
DanPatterson
SMangum
Thanks for all your help, Dan! Twenty billion layers later, I discovered the right workflow. Couldn't have done it without ya!
DanPatterson
glad it worked out!
