Calculate Geometry Error
5705
08-24-2023 04:38 AM
sjet1010
I created two fields for x, y coordinates. Every time I try to do a Calculate Geometry it errors out with no error number but it says,
     File "c:\...\ArcToolbox\scripts\calculategeometry.py", line 290, in <module>
         CalculateGeometry(fc, properties, lUnit, aUnit, cs, cformat)
File "c:\...\ArcToolbox\scripts\calculategeometry.py", line 130, in CalculateGeometry
      ucur.updateRow(row)
It has only done this so far with both my water and electric utility network databases, which can only be used via feature service. I ran a test on my other non-utility network layers that I access directly from the database and it works just fine.
AyanPalit
Updating this old thread for tracking and community documentation. Related post: https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-calculate-geometry/m-p/1667532
I added links to the Calculate Geometry Attributes as well as requirements of the field/data type for the geometry attributes. Check if you are using 'double' type for XY coordinates.
Ayan Palit | Principal Consultant Esri
TrevisMartin
What can you tell us about the feature service?  Is it editable, etc? The update cursor is failing which implies it doesn't have edit access to the service, or is being prevented by the feature service.  Are you making the x, y columns before the attempt to populate, or letting the tool create them?
sjet1010
I was trying it originally to my feature services that are part of a Utility Network, then I tested it on all my other editable layers that are not part of a Utility Network and still received the same error. I don't get the error when I try it with a layer directly from a database, but with layers that are part of a Utility Network you can only edit via feature service. The layers that I am pulling in are feature layers that have editable capabilities. I added the x y coordinate columns to the feature class.
kterry1983
Did you have any luck with this? I just attempted to calculate eastings into a feature service saved in the portal and received the error.
kterry1983
In my case, the error was caused by selecting the feature service using the drop down list in the tool. When I clicked on the folder icon and navigated to it in the portal, it worked.
AyanPalit
