Calculate Field with Python
1846
03-12-2021 05:52 PM
KalSsin
Hi~~~
!Name!.split('(')[0]
Name = Name.split('(')[0]
What should I do?
Thank you in advance.
DanPatterson
MVP Esteemed Contributor
if you clear everything,
then click until the field name appears in the expression line you should see
... sort of retired...
DanPatterson
KalSsin
Thank you so~~~~much
DanPatterson
@KalSsin if it worked you could "Accept as Solution" the correct answer so people know there was a solution and the question is now closed.  Thanks
