Calculate field stuck at 5% with SQL language
1534
11-02-2023 03:36 AM
SYSMANOFFICE
Good morning,
I have a problem with "Calculate field" using SQL
The process stucks at 5% when i use SQL language.
With python and arcade the process is slow but works.
I tried with string, number, field but I have same results.
This problem started monday 2023/10/30. Do you have same problem?
Do you have suggestions? Can you help me?
thanks
ChrisUnderwood
Hello @SYSMANOFFICE , please can you give us some more details about the "RUIUrbana" Table you are updating. Please find that Table in the map's table of contents, right-click select Properties, then select Source tab. Please post a screenshot of that Layer Properties form.
SYSMANOFFICE
The problem was solved with the next system update and maintenance
